Aller au contenu principal
IT BIBLESe connecter
Rockwell Automation Studio 5000 Logix Designer
  • CVSS v4 7.3
  • ATTENTION: Exploitable from a local network
  • Equipment: Studio 5000 Logix Designer
  • Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could allow an attacker to crash the device or execute malicious code.
The following versions of Studio 5000 Logix Designer, a centralized control system management software, are affected:
  • Studio 5000 Logix Designer: Version 36.00.02 to 37.00.02
A security issues exists within Studio 5000 Logix Designer due to unsafe handling of environment variables. If the specified path lacks a valid file, Logix Designer crashes; however, it may be possible to execute malicious code without triggering a crash.
CVE-2025-7971 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:L/AC:H/PR:L/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7971. A base score of 7.3 has been calculated; the CVSS vector string is (AV:L/AC:H/AT:N/PR:L/UI:P/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Critical Manufacturing
Rockwell Automation recommends users to update to version 37.00.02 or later if possible. If users of the affected software are unable to upgrade the version, security best practices should be applied.
No known public exploitation specifically targeting this vulnerability has been reported to CISA at this time. This vulnerability is not exploitable remotely. This vulnerability has a high attack complexity.
  • August 14, 2025: Initial Republication: Initial Republication of Rockwell Automation’s SD1734
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-29
Se connecter pour répondre.
