Delta Electronics DIAView
  • CVSS v4 9.3
  • Vendor: Delta Electronics
  • Equipment: DIAView
  • Vulnerability: Improper Limitation of a Pathname to a Restricted Directory
Successful exploitation of this vulnerability may allow a remote attacker to read or write files on the affected device.
Delta Electronics reports the following versions of DIAView industrial automation management system for providing real-time system control are affected:
  • DIAView: Versions 4.2.0.0
3.2.1 Improper Limitation of a Pathname to a Restricted Directory CWE-22
Delta Electronics DIAView is vulnerable to a path traversal vulnerability, which may allow an attacker to read or write files remotely on the system.
CVE-2025-53417 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53417. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Chemical, Commercial Facilities, Critical Manufacturing, Energy, Transportation Systems, Water and Wastewater Systems
hir0ot, working with Trend Micro Zero Day Initiative, reported this vulnerability to CISA.
Delta Electronics recommends users update to DIAView v4.3.0 or later.
For more information, see Delta Electronics advisory Delta-PCSA-2025-00010.
Delta Electronics offers users the following general recommendations:
  • Do not click on untrusted Internet links or open unsolicited attachments in emails.
  • Place control system networks and remote devices behind firewalls, and isolate them from the business network.
If you have any product-related support concerns, contact Delta via the portal page for any information or materials you may require.
  • August 7, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-219-01
