Packet Power EMX and EG
  • CVSS v4 9.3
  • Vendor: Packet Power
  • Equipment: EMX, EG
  • Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could allow an attacker to gain full access to the device without authentication.
The following Packet Power products are affected:
  • EMX: Versions prior to 4.1.0
  • EG: Versions prior to 4.1.0
By default, the Packet Power Monitoring and Control Web Interface do not enforce authentication mechanisms. This vulnerability could allow unauthorized users to access and manipulate monitoring and control functions.
CVE-2025-8284 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-8284. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Anthony Rose and Jacob Krasnov of BC Security reported this vulnerability to CISA.
Packet Power recommends the following:
  • Update the affected products to version 4.1.0 or later.
  • Isolate devices whenever possible.
  • Minimizing network exposure for all control system devices and/or systems, ensuring they are not accessible from the internet.
  • August 7, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-219-05
