Schneider Electric EcoStruxure
  • CVSS v4 5.3
  • Vendor: Schneider Electric
  • Equipment: EcoStruxure Power Monitoring Expert (PME) and EcoStruxure Power Operation (EPO)
  • Vulnerability: Exposure of Resource to Wrong Sphere
Successful exploitation of this vulnerability could provide other authenticated users with potentially inappropriate access to TGML diagrams.
Schneider Electric reports the following products are affected:
  • EcoStruxure Power Monitoring Expert (PME): 2023
  • EcoStruxure Power Monitoring Expert (PME): 2023 R2
  • EcoStruxure Power Monitoring Expert (PME): 2024
  • EcoStruxure Power Monitoring Expert (PME): 2024 R2
  • EcoStruxure Power Operation (EPO) Advanced Reporting and Dashboards Module: 2022
  • EcoStruxure Power Operation (EPO) Advanced Reporting and Dashboards Module: 2024
3.2 Vulnerability Overview
3.2.1 EXPOSURE OF RESOURCE TO WRONG SPHERE CWE-668
A resource exposure vulnerability exists that exposes TGML diagram resources to unauthorized control, allowing other authenticated users unauthorized access to TGML diagrams.
CVE-2025-6788 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-6788. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
Schneider Electric reported this vulnerability to CISA.
Schneider Electric has identified the following specific remediations users can apply to reduce risk:
  • EcoStruxure Power Monitoring Expert (PME) 2023, 2023 R2: Hotfix_199767 is available and includes a fix for this vulnerability.
  • EcoStruxure Power Monitoring Expert (PME) 2024: Hotfix_256448_Diagrams-Release.13.0.25182.01 is available and includes a fix for this vulnerability.
  • EcoStruxure Power Monitoring Expert (PME) 2024 R2: Hotfix_256448_Diagrams-Release.13.1.25182.01 is available and includes a fix for this vulnerability.
  • EcoStruxure Power Operation (EPO) Advanced Reporting and Dashboards Module 2022: Hotfix_199767 is available and includes a fix for this vulnerability.
  • EcoStruxure Power Operation (EPO) Advanced Reporting and Dashboards Module 2024: Hotfix_256448_Diagrams-Release.13.0.25182.0 is available and includes a fix for this vulnerability.
Contact Schneider Electric's Customer Care Center to download these hotfixes.
Schneider Electric recommends users employ appropriate patching methodologies when applying these patches to their systems. They strongly recommend making backups and evaluating the impact of these patches in a test and development environment or on offline infrastructure. Contact Schneider Electric's Customer Care Center for assistance removing a patch.
If users choose not to apply the above-mentioned remediation, Schneider Electric recommends the immediate removal of TGML diagrams from multi-tenant managed systems or on-premises systems and reverting to Vista diagrams.
For more information, see the associated Schneider Electric security advisory SEVD-2025-189-04: EcoStruxure Power Monitoring Expert (PME) and EcoStruxure Power Operation (EPO) with Advanced Reporting and Dashboards PDF version, CSAF version.
Schneider Electric strongly recommends adhering to the following industry cybersecurity best practices:
  • Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network.
  • Install physical controls to prevent unauthorized personnel from accessing industrial control and safety systems, components, peripheral equipment, and networks.
  • Place all controllers in locked cabinets and never leave them in the "Program" mode.
  • Never connect programming software to any network other than the one intended for that device.
  • Scan all methods of mobile data exchange with the isolated network, such as CDs, USB drives, etc., before use in terminals or any nodes connected to these networks.
  • Never allow mobile devices that have connected to any network other than the intended network to connect to safety or control networks without proper sanitation.
  • Minimize network exposure for all control system devices and systems, ensuring they are not accessible from the Internet.
  • When remote access is required, use secure methods such as Virtual Private Networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices. For more information, refer to the Schneider Electric recommended cybersecurity best practices document.
  • July 22, 2025: Initial Republication of Schneider Electric SEVD-2025-189-04
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-203-03
