Zum Hauptinhalt springen
IT BIBLEAnmelden
LITEON IC48A and IC80A EV Chargers
  • Vendor: LITEON
  • Equipment: IC48A and IC80A
  • Vulnerability: Plaintext Storage of a Password
Successful exploitation of this vulnerability could allow an attacker to access sensitive information when accessing the Liteon EV chargers.
The following versions of LITEON EV chargers are affected:
  • LITEON IC48A: Firmware versions prior to 01.00.19r
  • LITEON IC80A: Firmware versions prior to 01.01.12e
3.2.1 PLAINTEXT STORAGE OF A PASSWORD CWE-256
LITEON IC48A firmware versions prior to 01.00.19r and LITEON IC80A firmware versions prior to 01.01.12e store FTP-server-access-credentials in cleartext in their system logs.
CVE-2025-7357 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-7357. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Energy, Transportation Systems
Murat Sagdullaev of Electrada reported this vulnerability to CISA.
LITEON has released the following firmware versions for the following EV chargers:
  • LITEON IC48A: Firmware versions 01.00.20h
  • LITEON IC80A: Firmware versions 01.01.13m
For more information, contact LITEON.
  • July 15, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-196-03
Anmelden um zu antworten.
