Delta Electronics DTM Soft
  • CVSS v4 8.4
  • Vendor: Delta Electronics
  • Equipment: DTM Soft
  • Vulnerability: Deserialization of Untrusted Data
Successful exploitation of this vulnerability could allow an attacker to encrypt files referencing the application in order to extract information.
The following Delta Electronics products are affected:
  • DTM Soft: Versions 1.6.0.0 and prior
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Delta DTM Soft is vulnerable to a deserialization of untrusted data vulnerability which may allow an attacker to extract information.
CVE-2025-53415 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53415. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
kimiya working with Trend Micro Zero Day Initiative reported this vulnerability to CISA.
Delta has released a new version of DTM Soft on their Download Center and recommends users update to the latest version.
For more information, please see Delta Electronics' advisory Delta-PCSA-2025-00009..
  • July 10, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-191-07
