End-of-Train and Head-of-Train Remote Linking Protocol
  • CVSS v4 7.2
  • Standard: End-of-Train and Head-of-Train remote linking protocol
  • Equipment: End-of-Train and Head-of-Train devices
  • Vulnerability: Weak Authentication
Successful exploitation of this vulnerability could allow an attacker to send their own brake control commands to the end-of-train device, causing a sudden stoppage of the train which may lead to a disruption of operations, or induce brake failure.
The following version of End-of-Train and Head-of-Train remote linking protocol is affected:
  • End-of-Train and Head-of-Train remote linking protocol: All versions
3.2.1 WEAK AUTHENTICATION CWE-1390
The protocol used for remote linking over RF for End-of-Train and Head-of-Train (also known as a FRED) relies on a BCH checksum for packet creation. It is possible to create these EoT and HoT packets with a software defined radio and issue brake control commands to the EoT device, disrupting operations or potentially overwhelming the brake systems.
CVE-2025-1727 has been assigned to this vulnerability. A CVSS v3 base score of 8.1 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:C/C:L/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-1727. A base score of 7.2 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:L/VI:H/VA:H/SC:N/SI:H/SA:H).
  • CRITICAL INFRASTRUCTURE SECTORS: Transportation Systems
  • COUNTRIES/AREAS DEPLOYED: United States
Neil Smith and Eric Reuter reported this vulnerability to CISA.
The Association of American Railroads (AAR) is pursuing new equipment and protocols which should replace traditional End-of-Train and Head-of-Train devices. The standards committees involved in these updates are aware of the vulnerability and are investigating mitigating solutions.
The AAR Railroad Electronics Standards Committee (RESC) maintains this protocol which is used by multiple manufacturers across the industry, including Hitachi Rail STS USA, Wabtec, Siemens, and others. Users of EoT/HoT devices are recommended to contact their own device manufacturers with questions.
  • July 10, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-191-10
