Emerson ValveLink Products
  • CVSS v4 9.3
  • Vendor: Emerson
  • Equipment: ValveLink Products
  • Vulnerabilities: Cleartext Storage of Sensitive Information in Memory, Protection Mechanism Failure, Uncontrolled Search Path Element, Improper Input Validation
Successful exploitation of these vulnerabilities could allow an attacker with access to the system to read sensitive information stored in cleartext, tamper with parameters, and run un-authorized code.
The following ValveLink products are affected:
  • ValveLink SOLO: All versions prior to ValveLink 14.0
  • ValveLink DTM: All versions prior to ValveLink 14.0
  • ValveLink PRM: All versions prior to ValveLink 14.0
  • ValveLink SNAP-ON: All versions prior to ValveLink 14.0
3.2.1 CLEARTEXT STORAGE OF SENSITIVE INFORMATION IN MEMORY CWE-316
The product stores sensitive information in cleartext in memory. The sensitive memory might be saved to disk, stored in a core dump, or remain uncleared if the product crashes, or if the programmer does not properly clear the memory before freeing it.
CVE-2025-52579 has been assigned to this vulnerability. A CVSS v3 base score of 9.4 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L).
A CVSS v4 score has also been calculated for CVE-2025-52579. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:L/SC:N/SI:N/SA:N).
3.2.2 CLEARTEXT STORAGE OF SENSITIVE INFORMATION IN MEMORY CWE-316
The product stores sensitive information in cleartext within a resource that might be accessible to another control sphere.
CVE-2025-50109 has been assigned to this vulnerability. A CVSS v3 base score of 7.7 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-50109. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.3 PROTECTION MECHANISM FAILURE CWE-693
The product does not use or incorrectly uses a protection mechanism that provides sufficient defense against directed attacks against the product.
CVE-2025-46358 has been assigned to this vulnerability. A CVSS v3 base score of 7.7 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-46358. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.4 UNCONTROLLED SEARCH PATH ELEMENT CWE-427
The product uses a fixed or controlled search path to find resources, but one or more locations in that path can be under the control of unintended actors.
CVE-2025-48496 has been assigned to this vulnerability. A CVSS v3 base score of 5.1 has been calculated; the CVSS vector string is (AV:L/AC:H/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-48496. A base score of 5.9 has been calculated; the CVSS vector string is (AV:L/AC:H/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.5 IMPROPER INPUT VALIDATION CWE-20
The product receives input or data, but it does not validate or incorrectly validates that the input has the properties that are required to process the data safely and correctly.
CVE-2025-53471 has been assigned to this vulnerability. A CVSS v3 base score of 5.1 has been calculated; the CVSS vector string is (AV:L/AC:H/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-53471. A base score of 5.9 has been calculated; the CVSS vector string is (AV:L/AC:H/AT:N/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
Emerson reported these vulnerabilities to CISA.
Emerson recommends users update their Valvelink software to ValveLink 14.0 or later. The upgrade can be downloaded from the Emerson website.
For more information see the associated Emerson security notification.
  • July 8, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-189-01
