FESTO Hardware Controller, Hardware Servo Press Kit
  • CVSS v3 9.8
  • Vendor: FESTO
  • Equipment: Hardware Controller, Hardware Servo Press Kit
  • Vulnerabilities: Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection')
Successful exploitation of these vulnerabilities could allow an attacker to execute unauthorized system commands with root privileges.
FESTO reports the following products are affected:
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1: Version 4.0.14
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-MV: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-MV: Version 4.0.14
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-MV-S1: Version 4.0.14
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-MV-S1: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-YS-L1: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-YS-L2: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Controller CECC-X-M1-Y-YJKP: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Servo Press Kit YJKP: Versions 3.8.14 and prior
  • Festo Firmware installed on Festo Hardware Servo Press Kit YJKP-: Versions 3.8.14 and prior
In multiple versions of Festo Controller CECC-X-M1 product family, the http-endpoint "cecc-x-refresh-request" POST request doesn't check for port syntax. This can result in unauthorized execution of system commands with root privileges due to improper access control command injection.
CVE-2022-30311 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
3.2.2 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
In multiple versions of Festo Controller CECC-X-M1 product family, the http-endpoint "cecc-x-acknerr-request" POST request doesn't check for port syntax. This can result in unauthorized execution of system commands with root privileges due to improper access control command injection.
CVE-2022-30310 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
3.2.3 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
In multiple versions of Festo Controller CECC-X-M1 product family, the http-endpoint "cecc-x-web-viewer-request-off" POST request doesn't check for port syntax. This can result in unauthorized execution of system commands with root privileges due to improper access control command injection.
CVE-2022-30309 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
3.2.4 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
In multiple versions of Festo Controller CECC-X-M1 product family, the http-endpoint "cecc-x-web-viewer-request-on" POST request doesn't check for port syntax. This can result in unauthorized execution of system commands with root privileges due to improper access control command injection.
CVE-2022-30308 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
Q. Kaiser and M. Illes of ONEKEY Research Labs reported these vulnerabilities to Festo. CERT@VDE coordinated with and supported Festo in the publication of FSA-202201.
FESTO recommends users update to Firmware CECC-X 4.0.18 or later versions.
For more information see the associated Festo SE & Co. KG security advisory FSA-202201 VDE-2022-020: Festo: CECC-X-M1 - command injection vulnerabilities.
  • July 1, 2025: Initial Republication of Festo SE & Co. KG FSA-202201
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-182-04
