Aller au contenu principal
IT BIBLESe connecter
FESTO Didactic CP, MPS 200, and MPS 400 Firmware
  • CVSS v3 9.8
  • Vendor: FESTO Didactic
  • Equipment: CP, MPS 200, MPS 400
  • Vulnerability: Improper Restriction of Operations within the Bounds of a Memory Buffer
Successful exploitation of this vulnerability could allow an attacker to write arbitrary data and code to protected memory areas or read sensitive data to launch further attacks.
FESTO Didactic reports that the following products are affected:
  • FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic CP including S7 PLC(All versions): All versions
  • FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic MPS 200 Systems(All versions): All versions
  • FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic MPS 400 Systems(All versions): All versions
3.2.1 IMPROPER RESTRICTION OF OPERATIONS WITHIN THE BOUNDS OF A MEMORY BUFFER CWE-119
SIMATIC S7-1200 and S7-1500 CPU products contain a memory protection bypass vulnerability that could allow an attacker to write arbitrary data and code to protected memory areas or read sensitive data to launch further attacks. Siemens has released updates for several affected products and strongly recommends to update to the latest versions. Siemens recommends specific countermeasures for products where updates are not, or not yet available.
CVE-2020-15782 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
CERT@VDE coordinated with and supported Festo in the publication of FSA-202405.
FESTO Didactic has identified the following specific workarounds and mitigations users can apply to reduce risk:
  • (Product Group: FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic CP including S7 PLC(All versions), FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic MPS 200 Systems(All versions), FESTO Didactic Firmware Siemens Simatic S7-1500 / ET200SP (< V2.9.2) installed on FESTO Didactic MPS 400 Systems(All versions)), All affected products: Update Siemens Simatic S7-1500 / ET200SP Firmware to V2.9.2 or or higher
  • Siemens Simatic S7-1500 / ET200SP V2.9.2 installed on FESTO Didactic CP including S7 PLC are fixed versions for CVE-2020-15782
  • Siemens Simatic S7-1500 / ET200SP V2.9.2 installed on FESTO Didactic MPS 200 Systems are fixed versions for CVE-2020-15782
  • Siemens Simatic S7-1500 / ET200SP V2.9.2 installed on FESTO Didactic MPS 400 Systems are fixed versions for CVE-2020-15782
For more information see the associated Festo SE & Co. KG security advisory FSA-202405 VDE-2024-055: Festo: Siemens S7-1500/ET200SP CPU used in Festo Didactic products contains a memory protection bypass vulnerability.
  • July 1, 2025: Initial Republication of Festo SE & Co. KG FSA-202405
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-182-01
Se connecter pour répondre.
