TrendMakers Sight Bulb Pro
  • CVSS v4 5.3
  • Vendor: TrendMakers
  • Equipment: Sight Bulb Pro
  • Vulnerabilities: Use of a Broken or Risky Cryptographic Algorithm, Improper Neutralization of Special Elements used in a Command ('Command Injection')
Successful exploitation of these vulnerabilities could allow an attacker to capture sensitive information and execute arbitrary shell commands on the target device as root if connected to the local network segment.
The following versions of the Sight Bulb Pro Firmware are affected:
  • Sight Bulb Pro Firmware ZJ_CG32-2201: Version 8.57.83 and prior
3.2.1 USE OF A BROKEN OR RISKY CRYPTOGRAPHIC ALGORITHM CWE-327
During the initial setup of the device the user connects to an access point broadcast by the Sight Bulb Pro. During the negotiation, AES Encryption keys are passed in cleartext. If captured, an attacker may be able to decrypt communications between the management app and the Sight Bulb Pro which may include sensitive information such as network credentials.
CVE-2025-6521 has been assigned to this vulnerability. A CVSS v3 base score of 7.6 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-6521. A base score of 5.3 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:P/PR:H/UI:P/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN A COMMAND ('COMMAND INJECTION') CWE-77
Unauthenticated users on an adjacent network with the Sight Bulb Pro can run shell commands as root through a vulnerable proprietary TCP protocol available on Port 16668. This vulnerability allows an attacker to run arbitrary commands on the Sight Bulb Pro by passing a well formed JSON string.
CVE-2025-6522 has been assigned to this vulnerability. A CVSS v3 base score of 5.4 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:H/UI:R/S:U/C:L/I:H/A:L).
A CVSS v4 score has also been calculated for CVE-2025-6522. A base score of 5.2 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:H/UI:P/VC:L/VI:H/VA:L/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities
Fahim Balouch reported these vulnerabilities to CISA.
TrendMakers did not respond to CISA's request for coordination. Contact TrendMakers directly for more information.
CISA recommends that device users take defensive measures to minimize the risk of exploitation of these vulnerabilities, such as:
  • The encryption key is sent in the clear only during the initial device setup when the Sight Bulb Pro acts as an access point. Take appropriate physical security measures to minimize the risk of remote network captures or monitoring.
  • Utilize network monitoring or signature based detection to monitor for malicious activity.
  • June 26, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-177-02
