Kaleris Navis N4 Terminal Operating System
  • CVSS v4 9.3
  • Vendor: Kaleris
  • Equipment: Navis N4
  • Vulnerabilities: Deserialization of Untrusted Data, Cleartext Transmission of Sensitive Information
Successful exploitation of these vulnerabilities could allow an attacker to remotely exploit the operating system, achieve remote code execution, or extract sensitive information.
The following versions of Kaleris Navis N4, a terminal operating system, are affected:
  • Navis N4: Versions prior to 4.0
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
Kaleris NAVIS N4 ULC (Ultra Light Client) contains an unsafe Java deserialization vulnerability. An unauthenticated attacker can make specially crafted requests to execute arbitrary code on the server.
CVE-2025-2566 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-2566. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 CLEARTEXT TRANSMISSION OF SENSITIVE INFORMATION CWE-319
Kaleris NAVIS N4 ULC (Ultra Light Client) communicates insecurely using zlib-compressed data over HTTP. An attacker capable of observing network traffic between Ultra Light Clients and N4 servers can extract sensitive information, including plaintext credentials.
CVE-2025-5087 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.9 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-5087. A base score of 6.0 has been calculated; the CVSS vector string is (AV:N/AC:H/AT:N/PR:N/UI:P/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Transportation Systems
Kaleris reported these vulnerabilities to CISA.
Kaleris recommends users to implement the following versions or later:
  • Navis N4: Version 3.1.44+
  • Navis N4: Version 3.2.26+
  • Navis N4: Version 3.3.27+
  • Navis N4: Version 3.4.25+
  • Navis N4: Version 3.5.18+
  • Navis N4: Version 3.6.14+
  • Navis N4: Version 3.7.0+
  • Navis N4: Version 3.8.0+
If users are unable to update, Kaleris recommends following these mitigations:
  • If N4 does not need to be exposed to the internet, placing it behind a firewall.
  • If CAP needs to be exposed to the internet, disable the Ultra Light Client on the nodes being exposed. This can be done by blocking the Ultra Light Client URLs in the load balancer or firewall by blocking the following patterns: "url-pattern*.jnlp
  • The Ultra Light Client endpoint can also be disabled on the N4 Cluster node by commenting out relevant code in the web.xml file and restarting the server.
  • If the Ultra Light Client must be exposed to the Internet, do one of the following: a. Set up a secure VPN connection to allow access for known external parties. b. Set up an authenticated jump system (Citrix, VDI, Etc.). c. Whitelist external allowed IPs. (least secure option)
  • Additionally, the following controls should be applied: a. Restrict the number of N4 nodes exposed to the internet. b. Ensure that HTTPS is enabled and configured on the filewall/loadbalancer. c. Use a reliable third-party party firewall with built in DDOS protection that can detect unwanted intrusions.
  • Users are required to implement TLS in their load balancer. The setup for this is included in the Application Security Guide that is provided to all users.
  • A final option to consider is upgrading to N4 4.0, where the Ultra Light Client has been fully replaced with the HTML UI.
Kaleris has sent a security advisory to all customers running Kaleris software.
For more information, users should email [email protected]
  • June 24, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-175-01
