Fuji Electric Smart Editor
  • CVSS v4 8.4
  • Vendor: Fuji Electric
  • Equipment: Smart Editor
  • Vulnerabilities: Out-of-bounds Read, Out-of-bounds Write, Stack-based Buffer Overflow
Successful exploitation of these vulnerabilities could allow an attacker to execute arbitrary code.
The following Fuji Electric products are affected:
  • Smart Editor: Versions 1.0.1.0 and prior
3.2.1 OUT-OF-BOUNDS READ CWE-125
The affected product is vulnerable to an out-of-bounds read, which may allow an attacker to execute arbitrary code.
CVE-2025-32412 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-32412. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
The affected product is vulnerable to an out-of-bounds write, which may allow an attacker to execute arbitrary code.
CVE-2025-41413 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41413. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 STACK-BASED BUFFER OVERFLOW CWE-121
The affected product is vulnerable to a stack-based buffer overflow, which may allow an attacker to execute arbitrary code.
CVE-2025-41388 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41388. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
kimiya working with Trend Micro Zero Day Initiative reported these vulnerabilities to CISA.
Fuji Electric recommends users update to Smart Editor v1.0.2.0 or later.
  • June 17, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-168-04
