Saltar al contenido principal
IT BIBLEIniciar sesión
AVEVA PI Connector for CygNet
  • CVSS v4 6.9
  • Vendor: AVEVA
  • Equipment: PI Connector for CygNet
  • Vulnerabilities: Cross-site Scripting, Improper Validation of Integrity Check Value
Successful exploitation of these vulnerabilities could allow an attacker to persist arbitrary code in the administrative portal of the product or cause a denial-of-service condition.
The following versions of PI Connector for CygNet are affected:
  • PI Connector for CygNet: Version 1.6.14 and prior
3.2.1 Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting') CWE-79
A cross-site scripting vulnerability exists in PI Connector for CygNet Versions 1.6.14 and prior that, if exploited, could allow an administrator miscreant with local access to the connector admin portal to persist arbitrary JavaScript code that will be executed by other users who visit affected pages.
CVE-2025-4417 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:H/UI:R/S:C/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-4417. A base score of 6.9 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:H/UI:P/VC:N/VI:H/VA:N/SC:H/SI:H/SA:N).
3.2.2 Improper Validation of Integrity Check Value CWE-354
An improper validation of integrity check value vulnerability exists in PI Connector for CygNet Versions 1.6.14 and prior that, if exploited, could allow a miscreant with elevated privileges to modify PI Connector for CygNet local data files (cache and buffers) in a way that causes the connector service to become unresponsive.
CVE-2025-4418 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.4 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:H/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-4418. A base score of 6.7 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:H/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: United Kingdom
AVEVA Ethical Disclosure reported these vulnerabilities to CISA.
AVEVA recommends that organizations evaluate the impact of these vulnerabilities based on their operational environment, architecture, and product implementation. Users of affected product versions should apply security updates to mitigate the risk of exploit.
All affected versions of PI Connector for CygNet can be fixed by upgrading to PI Connector for CygNet v1.7.0 or higher. From OSISoft Customer Portal, search for "PI Connector for CygNet" and select Version 1.7.0 or higher.
AVEVA further recommends users follow general defensive measures:
  • Ensure that PI Connector for CygNet administrative access is only provided to trusted entities.
  • Audit custom installation folder Access Control Lists (ACLs) to ensure access is only provided to trusted entities.
  • Audit and limit membership to the OS Local "Administrators" and "PI Connector Administrators" groups.
For additional information please refer to AVEVA-2025-002.
  • June 12, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-09
