Aller au contenu principal
IT BIBLESe connecter
Schneider Electric Wiser Home Automation
  • CVSS v4 9.3
  • Vendor: Schneider Electric
  • Equipment: Wiser AvatarOn 6K Freelocate, Wiser Cuadro H 5P Socket
  • Vulnerability: Buffer Copy without Checking Size of Input ('Classic Buffer Overflow')
Successful exploitation of this vulnerability could allow an attacker to inject code or bypass authentication.
The following Schneider Electric products are affected:
  • Wiser AvatarOn 6K Freelocate: All versions
  • Wiser Cuadro H 5P Socket: All versions
3.2.1 Buffer Copy without Checking Size of Input ('Classic Buffer Overflow') CWE-120
Buffer Copy without Checking Size of Input ('Classic Buffer Overflow'), Out-of-bounds Write, Download of Code Without Integrity Check vulnerability in Silicon Labs Gecko Bootloader on ARM (Firmware Update File Parser modules) allows Code Injection, Authentication Bypass. This issue affects "Standalone" and "Application" versions of Gecko Bootloader.
CVE-2023-4041 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2023-4041. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Energy
Schneider Electric reported this vulnerability to CISA.
The Wiser AvatarOn 6K Freelocate and Wiser Cuadro H 5P Socket products have reached their end of life and are no longer supported. Users should immediately either disable the firmware update in the Zigbee Trust Center or remove the products from service to reduce the risk of exploitation.
To stay informed about all updates, including details on affected products and remediation plans, subscribe to Schneider Electric's security notification service here: https://www.se.com/en/work/support/cybersecurity/securitynotifications.jsp
  • June 3, 2025: Initial Republication of Schneider Electric SEVD-2025-133-02
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-153-01
Se connecter pour répondre.
