Aller au contenu principal
IT BIBLESe connecter
Santesoft Sante DICOM Viewer Pro
  • CVSS v4 8.4
  • Vendor: Santesoft
  • Equipment: Sante DICOM Viewer Pro
  • Vulnerability: Out-of-bounds Read
Successful exploitation of this vulnerability could allow an attacker to disclose information or execute arbitrary code.
The following Santesoft products are affected:
  • Sante DICOM Viewer Pro: Versions 14.2.1 and prior
3.2.1 OUT-OF-BOUNDS READ CWE-125
The affected product contains a memory corruption vulnerability. A local attacker could exploit this issue to potentially disclose information and to execute arbitrary code on affected installations of Sante DICOM Viewer Pro.
CVE-2025-5307 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-5307. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Healthcare and Public Health
  • COMPANY HEADQUARTERS LOCATION: Cyprus
Michael Heinzl reported this vulnerability to CISA.
Santesoft recommends users upgrade Sante DICOM Viewer Pro to version v14.2.2.
  • May 29, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-medical-advisories/icsma-25-148-01
Se connecter pour répondre.
