Zum Hauptinhalt springen
IT BIBLEAnmelden
Consilium Safety CS5000 Fire Panel
  • CVSS v4 9.3
  • Vendor: Consilium Safety
  • Equipment: CS5000 Fire Panel
  • Vulnerabilities: Initialization of a Resource with an Insecure Default, Use of Hard-coded Credentials
Successful exploitation of these vulnerabilities could allow an attacker to gain high-level access to and remotely operate the device, potentially putting it into a non-functional state.
The following Consilium Safety product is affected:
  • CS5000 Fire Panel: All versions
3.2.1 INITIALIZATION OF A RESOURCE WITH AN INSECURE DEFAULT CWE-1188
The CS5000 Fire Panel is vulnerable due to a default account that exists on the panel. Even though it is possible to change this by SSHing into the device, it has remained unchanged on every installed system observed. This account is not root but holds high-level permissions that could severely impact the device's operation if exploited.
CVE-2025-41438 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41438. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 USE OF HARD-CODED CREDENTIALS CWE-798
The CS5000 Fire Panel is vulnerable due to a hard-coded password that runs on a VNC server and is visible as a string in the binary responsible for running VNC. This password cannot be altered, allowing anyone with knowledge of it to gain remote access to the panel. Such access could enable an attacker to operate the panel remotely, potentially putting the fire panel into a non-functional state and causing serious safety issues.
CVE-2025-46352 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-46352. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Energy, Government Services and Facilities, Healthcare and Public Health, Transportation Systems
  • COMPANY HEADQUARTERS LOCATION: Sweden
Andrew Tierney of Pen Test Partners reported these vulnerabilities to CISA.
Consilium Safety is aware of these vulnerabilities. Currently, no fixes are planned for the CS5000 Fire Panel.
Users wanting enhanced security features are advised to upgrade to Consilium Safety's newer line of fire panels. Specifically, products manufactured after July 1, 2024, incorporate more secure-by-design principles.
Users of the CS5000 Fire Panel are recommended to implement compensating countermeasures, such as physical security and access control restrictions for dedicated personnel.
More product safety information can be found on Consilium Safety's support webpage.
  • May 29, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-148-03
Anmelden um zu antworten.
