Siemens SIRIUS 3SK2 Safety Relays and 3RK3 Modular Safety Systems
  • Equipment: SIRIUS 3RK3 Modular Safety System (MSS), SIRIUS Safety Relays 3SK2
  • Vulnerabilities: Use of a Broken or Risky Cryptographic Algorithm, Missing Encryption of Sensitive Data, Incorrect Permission Assignment for Critical Resource
Successful exploitation of these vulnerabilities could allow an attacker to retrieve and de-obfuscate safety password, eavesdrop connections, or retrieve sensitive information from certain data records.
  • SIRIUS 3RK3 Modular Safety System (MSS): All versions
  • SIRIUS Safety Relays 3SK2: All versions
3.2.1 USE OF A BROKEN OR RISKY CRYPTOGRAPHIC ALGORITHM CWE-327
Affected devices only provide weak password obfuscation. An attacker with network access could retrieve and de-obfuscate the safety password used for protection against inadvertent operating errors.
CVE-2025-24007 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-24007. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.2 MISSING ENCRYPTION OF SENSITIVE DATA CWE-311
The affected devices do not encrypt data in transit. An attacker with network access could eavesdrop the connection and retrieve sensitive information, including obfuscated safety passwords.
CVE-2025-24008 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-24008. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.3 INCORRECT PERMISSION ASSIGNMENT FOR CRITICAL RESOURCE CWE-732
The affected devices do not require authentication to access critical resources. An attacker with network access could retrieve sensitive information from certain data records, including obfuscated safety passwords.
CVE-2025-24009 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.9 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-24009. A base score of 8.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
Nikolai Puch, Johanna Latzel, and Ferdinand Jarisch from Fraunhofer AISEC reported these vulnerabilities to Siemens.
Siemens is preparing fixed versions and recommends countermeasures for products where fixes are not, or not yet available:
  • SIRIUS 3RK3 Modular Safety System (MSS): Currently no fix is planned.
  • SIRIUS Safety Relays 3SK2: Currently no fix is available.
  • Limit physical access to affected devices to trusted personnel.
  • Ensure network isolation of the PROFINET interface to prevent access from unauthorized systems.
For more information see the associated Siemens security advisory SSA-222768 in HTML and CSAF.
CISA recommends users take defensive measures to minimize the risk of exploitation of these vulnerabilities. CISA reminds organizations to perform proper impact analysis and risk assessment prior to deploying defensive measures.
  • May 15, 2025: Initial Republication of Siemens ProductCERT SSA-222768
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-13
