Siemens MS/TP Point Pickup Module
  • CVSS v4 7.1
  • ATTENTION: Exploitable from adjacent network/low attack complexity
  • Equipment: MS/TP Point Pickup Module
  • Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could allow an attacker to cause a denial of service condition that requires a power cycle to restore normal operation.
Siemens reports the following products are affected:
  • Siemens MS/TP Point Pickup Module: All versions
The affected devices improperly handle specific incoming BACnet MSTP messages. This could allow an attacker residing in the same BACnet network to send a specially crafted MSTP message that results in a denial of service condition of the targeted device. A power cycle is required to restore the device's normal operation.
CVE-2025-24510 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-24510. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Energy, Government Facilities, Healthcare and Public Health, Information Technology, Transportation Systems
  • MS/TP Point Pickup Module: Currently no fix is planned
For more information see the associated Siemens security advisory SSA-668154 in HTML and CSAF.
May 15, 2025: Initial Republication of Siemens ProductCERT SSA-668154
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-16
