Zum Hauptinhalt springen
IT BIBLEAnmelden
Vertiv Liebert RDU101 and UNITY
  • CVSS v4 9.3
  • Vendor: Vertiv
  • Equipment: Liebert RDU101 and Liebert UNITY
  • Vulnerabilities: Authentication Bypass Using an Alternate Path or Channel, Stack-based Buffer Overflow
Successful exploitation of these vulnerabilities could allow an attacker to cause a denial-of-service condition or achieve remote code execution
The following Vertiv products are affected:
  • Liebert RDU101: Versions 1.9.0.0 and prior
  • Liebert IS-UNITY: Versions 8.4.1.0 and prior
3.2.1 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
Affected Vertiv products do not properly protect webserver functions that could allow an attacker to bypass authentication.
CVE-2025-46412 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-46412. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 STACK-BASED BUFFER OVERFLOW CWE-121
Affected Vertiv products contain a stack based buffer overflow vulnerability. An attacker could exploit this vulnerability to gain code execution on the device.
CVE-2025-41426 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41426. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications, Energy
Vera Mens of Claroty Team82 reported this these vulnerabilities to CISA.
Vertiv recommends users take the following actions:
  • Update Liebert RDU101 to v1.9.1.2_0000001
  • Update IS-UNITY to v8.4.3.1_00160
For more information please contact Vertiv.
  • May 20, 2025: Initial Publication.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-140-10
Anmelden um zu antworten.
