Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electric Products
  • CVSS v4 8.3
  • Vendor: Mitsubishi Electric Iconics Digital Solutions, Mitsubishi Electric
  • Equipment: ICONICS Product Suite and Mitsubishi Electric MC Works64
  • Vulnerability: Execution with Unnecessary Privileges
Successful exploitation of this vulnerability could result in information tampering on the target workstation.
Mitsubishi Electric Iconics Digital Solutions reports that the following versions of ICONICS Product Suite and Mitsubishi Electric MC Works64 are affected:
  • GENESIS64 AlarmWorX Multimedia (AlarmWorX64 MMX): All Versions
  • Mitsubishi Electric MC Works64 AlarmWorX Multimedia (AlarmWorX64 MMX): All versions
3.2.1 EXECUTION WITH UNNECESSARY PRIVILEGES CWE-250
An execution with unnecessary privileges vulnerability in the AlarmWorX64 MMX Pager agent can provide the potential for information tampering. An attacker could make an unauthorized write to arbitrary files by creating a symbolic link from a file used as a write destination by the Pager Agent service of GENESIS64 and MC Works64 to a target file. This could allow the attacker to destroy the file on a PC with GENESIS64 or MC Works64 installed, resulting in a denial-of-service (DoS) condition on the PC.
CVE-2025-0921 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:C/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-0921. A base score of 8.3 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:L/UI:N/VC:N/VI:H/VA:H/SC:N/SI:H/SA:H.
Asher Davila and Malav Vyas from Palo Alto Networks reported this vulnerability to Mitsubishi Electric and CISA.
Mitsubishi Electric recommends that users take the following mitigations to minimize the risk of exploiting this vulnerability:
  • If you do not need to use the multi-agent notification feature, please uninstall it. The multi-agent notification feature is not included in the default installation of GENESIS64TM version 10.97.3 or later. For users engaging the multi-agent notification feature who do not also need to the Pager agent, please execute a custom installation of the multi-agent notification feature and skip the installation of the Pager agent.
  • Please configure the PCs with the affected product installed so that only an administrator can log in.
  • PCs with the affected product installed should be configured to block remote logins from untrusted networks and hosts, and from non-administrator users.
  • Block unauthorized access by using a firewall or virtual private network (VPN), etc., and allow remote login only to administrators when connecting the PCs with the affected product installed to the Internet.
  • Restrict physical access to the PC with the affected product installed and the network to which the PC is connected to prevent unauthorized physical access.
  • Do not click on web links in emails from untrusted sources. Also, do not open attachments in untrusted emails.
  • Mitsubishi Electric Iconics Digital Solutions and Mitsubishi Electric recommends updating the ICONICS Suite with the latest security patches as they become available. ICONICS Suite security patches may be found at the following link: https://partners.iconics.com/Home.aspx. Note that a login is required.
  • Refer to the Mitsubishi Electric Iconics Digital Solutions Whitepaper on Security Vulnerabilities, the most recent version of which can be found at: https://iconics.com/About/Security/CERT
  • Refer to the Mitsubishi Electric security advisory at: https://www.mitsubishielectric.com/psirt/vulnerability/pdf/2025-002_en.pdf for information on the availability of the security updates.
  • May 20, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-140-04
