Saltar al contenido principal
IT BIBLEIniciar sesión
Assured Telematics Inc (ATI) Fleet Management System with Geotab Integration
  • Vendor: Assured Telematics Inc.
  • Equipment: Fleet Management System
  • Vulnerabilities: Exposure of Sensitive System Information to an Unauthorized Control Sphere
Successful exploitation of this vulnerability could result in an attacker collecting sensitive file system information or obtain administrative credentials.
The following product is affected:
  • Fleet Management System: Versions prior to February 6th, 2025
3.2.1 EXPOSURE OF SENSITIVE SYSTEM INFORMATION TO AN UNAUTHORIZED CONTROL SPHERE CWE-497
The affected products could allow an unauthenticated attacker to access system information that could enable further access to sensitive files and obtain administrative credentials.
CVE-2025-4364 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-4364. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Transportation Systems
Nicholas Michael Kloster reported this vulnerability to CISA.
Assured Telematics reports that they have fixed the exposure of sensitive information.
Contact Assured Telematics for more information
  • May 20, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-140-11
