Zum Hauptinhalt springen
IT BIBLEAnmelden
National Instruments Circuit Design Suite
  • CVSS v4 8.4
  • Vendor: National Instruments
  • Equipment: Circuit Design Suite
  • Vulnerabilities: Out-of-bounds Write, Out-of-bounds Read, Stack-based Buffer Overflow
Successful exploitation of these vulnerabilities could allow an attacker to disclose information or execute arbitrary code.
The following National Instruments products are affected:
  • Circuit Design Suite: Versions 14.3.0 and prior
An out-of-bounds write vulnerability in DecodeBase64() within Circuit Design Suite, caused by improper input validation, may result in arbitrary code execution. To exploit this flaw, an attacker must trick a user into opening a specially crafted SYM file.
CVE-2025-30417 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30417. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
An out-of-bounds write vulnerability in CheckPins() within Circuit Design Suite, caused by improper input validation, may result in arbitrary code execution. To exploit this flaw, an attacker must trick a user into opening a specially crafted SYM file.
CVE-2025-30418 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30418. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 OUT-OF-BOUNDS READ CWE-125
An out-of-bounds read vulnerability in GetSymbolBorderRectSize() within Circuit Design Suite, caused by improper input validation, may result in information disclosure or arbitrary code execution. To exploit this flaw, an attacker must trick a user into opening a specially crafted SYM file.
CVE-2025-30419 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30419. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 OUT-OF-BOUNDS READ CWE-125
An out-of-bounds read vulnerability in InternalDraw within Circuit Design Suite, caused by improper input validation, may result in information disclosure or arbitrary code execution. To exploit this flaw, an attacker must trick a user into opening a specially crafted SYM file.
CVE-2025-30420 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30420. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.5 STACK-BASED BUFFER OVERFLOW CWE-121
A stack-based buffer overflow vulnerability within Circuit Design Suite, caused by improper input validation, may result in arbitrary code execution. To exploit this flaw, an attacker must trick a user into opening a specially crafted SYM file.
CVE-2025-30421 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30421. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications, Defense Industrial Base, Government Services and Facilities
Michael Heinzl reported these vulnerabilities to CISA.
National Instruments recommends users update to version 14.3.1 or later.
Please see National Instruments security update for more information.
CISA recommends users take defensive measures to minimize the risk of exploitation of this these vulnerabilities, such as:
  • May 20, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-140-02
Anmelden um zu antworten.
