Forum / Servers / Server Software
How to Install and Configure OpenVPN Server and Client for Routing (and other things)
I try to keep my posts / tutorials as concise as possible but in some cases I'm not able to do that, and this is one of those cases. This is a longer one but it will be at the core of something I want to do within my lab.
sudo apt update
sudo apt install openvpn
Download and install EasyRSA (in this example we are using version 3.1.1)
wget -P ~/ https://github.com/OpenVPN/easy-rsa/releases/download/v3.1.1/EasyRSA-3.1.1.tgz
cd ~
tar xvf EasyRSA-3.1.1.tgz
cd ~/EasyRSA-3.1.1
#set_var EASYRSA_REQ_COUNTRY    "US"
#set_var EASYRSA_REQ_PROVINCE   "California"
#set_var EASYRSA_REQ_CITY       "San Francisco"
#set_var EASYRSA_REQ_ORG        "Copyleft Certificate Co"
#set_var EASYRSA_REQ_EMAIL      "[email protected]"
#set_var EASYRSA_REQ_OU         "My Organizational Unit"
Un-comment each line and update to your information
set_var EASYRSA_REQ_PROVINCE   "Kansas"
set_var EASYRSA_REQ_CITY       "Kansas City"
set_var EASYRSA_REQ_ORG        "IT Bible"
set_var EASYRSA_REQ_OU         "Community"
Initialize the public key infrastructure (pki) ./easyrsa init-pki Build the Certificate Authority for the ease of the tutorial I'm going to use the nopass option so it doesn't prompt for the CA password each time ./easyrsa build-ca nopass The common name can be any string of characters but for simplicity's sake we're going to use the defaults
so lets create our CSR ./easyrsa gen-req pop01.nyc1 nopass The command we just ran created both pop01.nyc1.req which is the CSR and also created pop01.nyc1.key which is the private key for the certificate.
Now lets copy the private key to our openvpn folder sudo cp pki/private/pop01.nyc1.key /etc/openvpn/server.key Now lets sign the request ./easyrsa sign-req server pop01.nyc1 verify the details and to confirm enter yes if you didn't use nopass in the build-ca step you'll be required to enter a password here Now we should have an issued certificate in pki/issued/ so lets check. ls -la pki/issued/ Lets create a Diffie-Hellman key, this will take a few minutes so grab a coffee or something while you wait. This key is used during the key exchange. I'll fast-forward though ./easyrsa gen-dh The next step is to create our servers HMAC signature, this helps stregthen the servers TLS integrity verification. openvpn --genkey secret ta.key We're going to copy these files into our OpenVPN config for use by the OpenVPN Server
sudo cp ta.key /etc/openvpn/
sudo cp pki/dh.pem /etc/openvpn/
sudo cp pki/issued/pop01.nyc1.crt /etc/openvpn/server.crt
sudo cp pki/ca.crt /etc/openvpn/ca.crt
Edit the default IP Forwarding rule sudo nano /etc/sysctl.conf remove the comment # from the line that contains
net.ipv4.ip_forward=1
then update the current session by running sudo sysctl -p Lets find the default interface (for use in a later step) ip route | grep default and lets edit the UFW before rules sudo nano /etc/ufw/before.rules Just under the start of the file you should have some commented text that looks similar to below, we're going to want to add our next lines right under that.
# rules.before
# Rules that should be run before the ufw command line added rules. Custom
# rules should be added to one of these chains:
#   ufw-before-input
#   ufw-before-output
#   ufw-before-forward
so under that description block on the file we're going to want to add our own custom rules that look like below (be sure to leave the lines below it that were there previously, we're just appending between the comment block and the existing rules)
# START OPENVPN
*nat
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -s 10.253.0.0/24 -o eth0 -j MASQUERADE
COMMIT
# END OPENVPN
Now you can also do some othe really cool stuff in this block, but we'll touch on that in a speperate video.
Now we need to tell UFW to allow forwarded packets sudo nano /etc/default/ufw find the line (CTRL+W if you're using nano) DEFAULT_FORWARD_POLICY and change it from DROP to ACCEPT and then save and close the file. If you didn't change the default port of OpenVPN then we also need to allow that port along with SSH through UFW.
sudo ufw allow 443/tcp
sudo ufw allow OpenSSH
now lets disable and re-enable UFW
sudo ufw disable
sudo ufw enable
sudo cp /usr/share/doc/openvpn/examples/sample-config-files/server.conf /etc/openvpn
sudo nano /etc/openvpn/server.conf
For this example we are going to be sure to setup the specific cipher we want as well as convert our port to 443/tcp so that we can get around firewalls that may be blocking based off the port instead of the type of traffic.
You're going to want to use Ctrl+W on this quite a bit and find each of the first parts of the lines, the config below is reflective of what you want it to look like when you're done.
port 443 #by default this is 1194
proto tcp
ca ca.crt
cert server.crt
key server.key
dh dh.pem
server 10.253.0.0 255.255.255.0 #this can be any private subnet but for my use this is what I chose.
tls-auth ta.key 0
cipher AES-256-CBC
user nobody
group nogroup
explicit-exit-notify 0 #this is only required because we are using tcp instead of udp
sudo systemctl start openvpn@server
sudo systemctl enable openvpn@server
● [email protected] - OpenVPN connection to server
     Loaded: loaded (/lib/systemd/system/[email protected]; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2022-11-06 05:47:02 UTC; 6 days ago
       Docs: man:openvpn(8)
             https://community.openvpn.net/openvpn/wiki/Openvpn24ManPage
             https://community.openvpn.net/openvpn/wiki/HOWTO
   Main PID: 5535 (openvpn)
     Status: "Initialization Sequence Completed"
      Tasks: 1 (limit: 2266)
     Memory: 3.4M
        CPU: 9min 12.758s
     CGroup: /system.slice/system-openvpn.slice/[email protected]
             └─5535 /usr/sbin/openvpn --daemon ovpn-server --status /run/openvpn/server.status 10 --cd /etc/openvpn --script-security 2 --config /etc/openvpn/server.conf --writepid /run/openvpn/server.pid
# Sample client-side OpenVPN 2.0 config file #
# for connecting to multi-client server.     #
# This configuration can be used by multiple #
# clients, however each client should have   #
# its own cert and key files.                #
# This configuration was originally modified #
# for use in IT Bible Tutorial find us on    #
# YouTube.com/@ITBible or www.itbible.org    #
# On Windows, you might want to rename this  #
# file so it has a .ovpn extension           #
# Specify that we are a client and that we
# will be pulling certain config file directives
# from the server.
client
# Use the same setting as you are using on
# the server.
# On most systems, the VPN will not function
# unless you partially or fully disable
# the firewall for the TUN/TAP interface.
;dev tap
dev tun
# Windows needs the TAP-Win32 adapter name
# from the Network Connections panel
# if you have more than one.  On XP SP2,
# you may need to disable the firewall
# for the TAP adapter.
;dev-node MyTap
# Are we connecting to a TCP or
# UDP server?  Use the same setting as
# on the server.
proto tcp
;proto udp
# The hostname/IP and port of the server.
# You can have multiple remote entries
# to load balance between the servers.
remote SERVER_IP SERVER_PORT #default port = 1194
# Choose a random host from the remote
# list for load-balancing.  Otherwise
# try hosts in the order specified.
;remote-random
# Keep trying indefinitely to resolve the
# host name of the OpenVPN server.  Very useful
# on machines which are not permanently connected
# to the internet such as laptops.
resolv-retry infinite
# Most clients don't need to bind to
# a specific local port number.
nobind
# Downgrade privileges after initialization (non-Windows only)
user nobody
group nobody
# Try to preserve some state across restarts.
persist-key
persist-tun
# Verify server certificate by checking that the
# certificate has the correct key usage set.
# This is an important precaution to protect against
# a potential attack discussed here:
#  http://openvpn.net/howto.html#mitm
# To use this feature, you will need to generate
# your server certificates with the keyUsage set to
#   digitalSignature, keyEncipherment
# and the extendedKeyUsage to
#   serverAuth
# EasyRSA can do this for you.
remote-cert-tls server
# Select a cryptographic cipher.
# If the cipher option is used on the server
# then you must also specify it here.
# Note that v2.4 client/server will automatically
# negotiate AES-256-GCM in TLS mode.
# See also the data-ciphers option in the manpage
cipher AES-256-CBC
# Set log file verbosity.
verb 3
key-direction 1
; script-security 2
; up /etc/openvpn/update-resolv-conf
; down /etc/openvpn/update-resolv-conf
; script-security 2
; up /etc/openvpn/update-systemd-resolved
; down /etc/openvpn/update-systemd-resolved
; down-pre
; dhcp-option DOMAIN-ROUTE .
Lets go ahead and sign it ./easyrsa sign-req client home Confirm that you're signing a trusted source by entering yes and if you didn't use nopass on the CA you'll need to enter your CA password again.
#!/bin/bash
# Original Author Mark Drake
# https://www.digitalocean.com/community/tutorials/how-to-set-up-an-openvpn-server-on-ubuntu-18-04#step-9-generating-client-configurations
# Slight modifications by WizardTux
# https://itbible.org
# First Argument is the common name of the certificate
EASYRSA_DIR=~/EasyRSA-3.1.1
OUTPUT_DIR=~/client-configs
BASE_CONFIG=~/client-configs/base.conf
cat ${BASE_CONFIG} \
    <(echo -e '<ca>') \
    ${EASYRSA_DIR}/pki/ca.crt \
    <(echo -e '</ca>\n<cert>') \
    ${EASYRSA_DIR}/pki/issued/${1}.crt \
    <(echo -e '</cert>\n<key>') \
    ${EASYRSA_DIR}/pki/private/${1}.key \
    <(echo -e '</key>\n<tls-auth>') \
    ${EASYRSA_DIR}/ta.key \
    <(echo -e '</tls-auth>') \
    > ${OUTPUT_DIR}/${1}.ovpn
We'll need this file executible chmod +x ~/client-configs/make_config.sh
