Posting Questions
  • Welcome to ITBible, we're your #1 resource for enterprise or homelab IT problems (or just a place to show off your stuff).
Administrator
Staff member
Diamond Supporter
Partner
Beta Tester
TCC-OG
Network Engineer
Sep 22, 2022
193
15
153
Shawnee, Kansas, USA
itbible.org
We just want to set a few posting guidelines for when you're posting a question.
Make sure to mark it as the question type when posting.​
This helps ensure that you get all of the correct options and lets everyone know you're looking for an answer to something. With a few exceptions all forums should have the option to post a question.
Please be sure to check for the answer to your question before posting.​
We may of already answered it before and this reduces clutter of the same question over and over again.
Mark the question as solved when its solved.​
If someone posts the answer to your question be sure to mark it as the solution (it gives them points and helps their community standing).
Failure to follow guidelines.​
If you fail to follow the guidelines outlined here your post may be deleted and repeated failure to follow them may result in a ban. These guidelines are subject to change without notice.
  • Like
Reactions: Andy
