I wanted a way to standardize the tests that our techs run when troubleshooting network issues. I've started this script as a beginning though I intend for it to be an EXE in the long run.
Any updates to this script can be found on our GitHub.
PowerShell:
.NOTES
Created on: 12/10/2022 10:37 PM
Created by: WizardTux
Organization: IT Bible (itbible.org)
Filename:
.DESCRIPTION
A description of the file.
$Domains = @(
"google.com",
"itbible.org"
$Resolvers = @(
"208.67.222.222",
"8.8.8.8"
$Gateway = Get-NetRoute | where { $_.DestinationPrefix -eq '0.0.0.0/0' } | Select -index 0 | select -ExpandProperty NextHop
$Externals = @(
"8.8.8.8"
"208.67.222.222"
function Run-DnsCustom
param (
[bool]$clear = $true
if ($clear) { [System.Console]::Clear() }
$DnsInput = Read-Host "Custom DNS lookup"
if ($DnsInput)
$ResolverInput = Read-Host "Custom Resolver [Local]"
Write-Host "Testing DNS... Please wait..."
if ($ResolverInput)
Write-Host "Testing Custom DNS using $ResolverInput : $DnsInput" -ForegroundColor Yellow -BackgroundColor Black
Resolve-DnsName -Name $DnsInput -Server $ResolverInput
else
Write-Host "Testing Custom DNS using Local Resolver: $DnsInput" -ForegroundColor Yellow -BackgroundColor Black
if ($clear) { Pause }
Exit
Exit
function Run-Dns
param (
Write-Host "Testing Local DNS" -ForegroundColor Yellow -BackgroundColor Black
foreach ($domain in $Domains)
Resolve-DnsName -Name $domain -DnsOnly
Write-Host ""
Write-Host "Testing Remote DNS" -ForegroundColor Yellow -BackgroundColor Black
$rCount = 0
foreach ($resolver in $Resolvers)
if ($rCount -gt 0) { Write-Host "" }
Write-Host "Resolver: $resolver" -ForegroundColor DarkRed
Resolve-DnsName -Name $domain -Server $resolver
$rCount++
function Run-Trace
param (
Write-Host "Testing Traceroute... Please wait..."
Write-Host "Tracing Gateway (should return 1 hop)" -ForegroundColor Yellow -BackgroundColor Black
Test-NetConnection -TraceRoute -ComputerName $Gateway
Write-Host ""
Write-Host "Tracing Remote Addresses" -ForegroundColor Yellow -BackgroundColor Black
$tCount = 0
foreach ($external in $Externals)
if ($tCount -gt 0) { Write-Host "" }
Write-Host "Tracing: $external"
Test-NetConnection -TraceRoute -ComputerName $external
function Run-PingCustom
param (
$PingInput = Read-Host "Custom Address"
if ($PingInput)
Write-Host "Testing PING... Please wait..."
Test-Connection -ComputerName $PingInput -Count 4
Exit
#start powershell { dns.ps1 }
Exit
function Run-Ping
param (
[bool]$clear=$true
if($clear) { [System.Console]::Clear() }
Write-Host "Testing Ping... Please wait..."
Write-Host "Pinging Gateway: $Gateway" -ForegroundColor Yellow -BackgroundColor Black
Test-Connection -ComputerName $Gateway -Count 4
Write-Host ""
Write-Host "Pinging External: $($Externals[0])" -ForegroundColor Yellow -BackgroundColor Black
Test-Connection -ComputerName $Externals[0] -Count 4
function Run-All
Write-Host "Testing All... Please wait..."
Run-Ping -clear $false
Run-Trace -clear $false
Run-Dns -clear $false
Pause
function Show-Menu
param (
[string]$Title = "ITBible Menu"
Write-Host "================ $Title ================"
Write-Host "Enter a number for diagnostic selection."
Write-Host "1: Run all network Scripts" -ForegroundColor DarkGray
Write-Host "2: Ping Test"
Write-Host "2a: Custom Ping Test"
Write-Host "3: Trace Test"
Write-Host "4: DNS Test"
Write-Host "4a: Custom DNS Test"
Write-Host ""
Write-Host "Q: Quit"
do
Show-Menu -Title "ITBible Network Diag"
$UserInput = Read-Host "Please make a selection"
switch ($UserInput)
'1' { Run-All }
'2' { Run-Ping }
'2a' { Run-PingCustom }
'3' { Run-Trace }
'4' { Run-Dns }
'4a' { Run-DnsCustom }
until ($UserInput -eq 'q')
